turchekj
#1 Posted : Wednesday, August 11, 2010 8:46:02 AM(UTC)
turchekj
stopped working belt worn motor pulley slightly melted from friction everything seems to move freely i believe belt stretched due to heat washer is outside in 100+ weather how do i get pulley off the easiest way
#2 Posted : Wednesday, August 11, 2010 12:41:54 PM(UTC)
Try to slide it out or just break it in pieces using a chisel.
- The motor pulley Part number: AP4024152
How to Remove Motor Pulley? (Washer Repair)
by dawabu 6/24/2010 2:59:24 PM(UTC)
