MasterDIY
#1 Posted : Monday, August 25, 2008 7:20:30 AM(UTC)
MasterDIY
I recently replaced the pump motor seal due to wate leaks. Since then, the dishwasher tripped the circuit breaker before the wash cycle is finished. There is not particular time or wash cycle which trigger the trip. Your suggestion is appreciated.
Regards,
HC
abadfish66
#2 Posted : Monday, August 25, 2008 8:04:31 AM(UTC)
abadfish66
I would check the wire connections at the junction box. The little metal box at the front right where the house wiring connects to the dishwasher wiring.
