raptor01
#1 Posted : Monday, August 25, 2008 6:41:38 AM(UTC)
raptor01
Dryer has sensor dry option that does not seem to work anymore. If put on time dry it dries the clothes but takes longer than it should. It's run this way for quite a while. It now squeaks too.
libertyappl
#2 Posted : Monday, August 25, 2008 6:57:52 AM(UTC)
libertyappl
Check you venting for obstructions and clean out any lint inside the dryer especially check the rollers. See if that helps.
Nat
Maytag Neptune Issues (Washer Repair)
by JGUIDI 5/5/2010 12:06:20 PM(UTC)
