The touch control panel on my Whirlpool gas range GW395LEPB00 is completely dead. The clock is still on and there is the PF code showing. I had the migration control panel replaced once under warranty already when the same problem occurred. It worked for about a year and a half.
Is it possible that moisture gets to the migration control panel and shorts it out? Will replacing the panel fix the problem or could it be something else?
I am thinking of buying the part (#9760013) and replace it myself. Whirlpool says there is no recall on this model yet, and that they could not help me. Thanks for any replies.
Try clearing the code, look on your tech sheet inside the conrtol panel and it will tell you haw to clear it. On another note the part number you listed isn't the part number shown for your model number I see part 9757264 Post your results. nat
