The "heated dry" display light comes on and we can't turn it off. We never use "heated dry" cycle.
Can you post the whole model number off your dishwasher, it's located on a tag on the frame when you open the door. Nat
Try to run a diagnostic.... A Field Service Test may be started by pressing the key 5 times followed by the key within 6 seconds. This test must be performed with clean water to insure proper sensor performance. “88” will appear in the display (if available*)
Try this and post what your display reads Nat
What do you mean by "key"? Thanks
The button is the key. nat
