When opening the stand alone GE Monogram Icemaker door the gasket pulls out on the top left corner. It is now pulling more and more of the gasket out. We press it back in, but each time it is opened seems a wider section of the gasket pulls loose. How do you reattach the gasket so it will stay permanently?
If a push on gasket, I would cement it in with clear silicone cement (RTV) available at Wall Mart. Just keep the door closed for a few hours so the cement gets dry. Eventually, you will need a new gasket.
