iceman382
#1 Posted : Friday, August 22, 2008 7:18:04 AM(UTC)
iceman382
Motor spins and lower spray arm moves freely.....
With Outlet cover off I can see the motor spin down if I quickly open the dishwasher door. Tried using CLR cleaner on 1 wash/rinse cycle.
Not spraying water and cleaning dishes. Spray arm looks clean and so does power clean filter.
Any ides?
I Replaced Outlet #AP3964091 and same thing.
Thanks.
Robert
libertyappl
#2 Posted : Friday, August 22, 2008 7:48:20 AM(UTC)
libertyappl
Check the check balls item # 7 on the pump & motor breakdown page.
