I have a Frigidaire side-by-side that is not dispensing ice or water. It worked earlier in the day then a couple of hours later... nothing. I am guessing that the water valve is ok as it is not leaking. The mechanism is not working for the ice maker or water dispenser. I hear nothing when I depress the lever. A switch perhaps that is in the freezer itself? What do you think?
please post your entire model number located inside the frig on the side wall.
The fridge is now working again. I guess it just had to sleep on it. The next day I tried it and it worked. I did nothing to fix it. Weird eh? I guess you can forget this one for now. Hopefully this will not happen agan.
