This washer is mis-behaving
I ran the washer. I put it on cold/cold and it half filled with hot and stopped. I waited. It was dead.
I roughed it up some and the dropped the lid a couple of times. That woke it up and it finished filling but with warm.
It washed my rags and drained and spun. Then stopped for good. No rinse. I am thinking it needs more than a lid switch.
Anyway: Kenmore 90 Series Model 110.26934690 Stock 26934 Serial CF 2801409
Anyone know what is going on with this washer?
Thanks for any help.
Could be a number of things along with the lid switch. My suggestion would be have a tech come check it as there should be several things checked. Nat
Originally Posted by: libertyappl  Could be a number of things along with the lid switch. My suggestion would be have a tech come check it as there should be several things checked. Nat "should be several things checked" - such as? I'm good with a meter, so would appreciate some pointers. Thanks!
