The digital board on my Whirlpool dryer will not operate, the light inside the dryer comes on when you open the door so I know I have power to the dryer.
I had a service tech. come out and check it out, and he said it was the electrical board. I ordered and installed the computer board and the display and dryer worked great-----ONE TIME :( . When I tried to run it with the next load of cloths, NOTHING was working just like before. Do you have any suggestions on what else it could be?
Check your connections first a wire may not have a good contact. Nat
I would also check where the dryer cord attaches to the dryer, and make sure you have 240 volts at the dryer block, look for burnt or loose wire there.
