badodd
#1 Posted : Thursday, August 5, 2010 5:15:33 PM(UTC)
badodd
Atlantis Series:
How do I remove the washer basket after I have removed the four transmission bolts?
It really seems stuck tight. Can any one help me with ideas?
ThatGuy
#2 Posted : Friday, August 6, 2010 3:07:39 AM(UTC)
ThatGuy
Groups: Expert
United States
Originally Posted by: badodd Go to Quoted Post
Atlantis Series:
As far as I can remember it just pulls up off that hub. It may be stuck, try turning it and wiggling it.
Maytag washer leaks on power wash cycle (Washer Repair)
by homeland1984 8/1/2020 8:44:37 AM(UTC)
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 6/22/2015 5:52:31 PM(UTC)
Maytag Washer leaks (Washer Repair)
by A00446849 2/20/2012 9:31:31 AM(UTC)
Maytag Washer leaks on side of drain hose (Washer Repair)
by della 12/17/2011 10:34:04 PM(UTC)
maytag washer leaks (Washer Repair)
by kramler92 12/7/2011 4:47:43 PM(UTC)
Maytag Washer leaks at bottom (Washer Repair)
by ronf 10/23/2010 6:07:28 AM(UTC)
Maytag washer leaks on the bottoom (Washer Repair)
by Bummer plumber 9/9/2010 7:56:24 AM(UTC)
by fabian g 7/1/2010 4:53:31 PM(UTC)
Maytag washer leaks as soon as its filling (Washer Repair)
by TonyCud01 4/3/2010 8:21:11 AM(UTC)
Maytag Washer Leaks at Drain Cycle (Washer Repair)
by ganzhimself 12/13/2009 6:52:55 PM(UTC)
Maytag Washer Leaks (Washer Repair)
by mriley44 12/9/2008 2:02:03 PM(UTC)
Maytag washer leaks (Washer Repair)
by smcneil 5/10/2008 11:37:29 AM(UTC)
My Maytag washer leaks onto floor (Washer Repair)
by mbrew5335 12/26/2007 12:21:13 PM(UTC)
