Leslie1217
#1 Posted : 15 years ago
Leslie1217
My built in ice tray started producing hollow ice. Then it became unpredictable as to if it made ice or not. Now it rarely makes ice and if it does, they are pieces of ice cubes, not entire cubes. Help.
Joe / APP Team
#2 Posted : 15 years ago
Joe / APP Team
My first guess,
You have a low water supply to the ice maker.
Have you replaced the water filter recently ?
It should be replaced at least once a year(it may be clogged/restricted).
You may want to install the bypass plug, as a test and see if production improves. (indicating a clogged filter or poor water supply).
Part number: AP4343647
Part number: AP4014279
Check you freezer temperature (On the middle shelf) it should be 0 to5 degrees).
After these checks and tests, if your problem persists, you will need to check the water supply and water valves, on the back of the refrigerator.
Part number: AP4009555
Part number: AP4013716
I've attached part numbers and descriptions for you,to familliarise you with the parts you may need.
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 2 years ago
Ice maker not working properly (Refrigerator & Freezer Repair)
by beckelhoff@cox.net 13 years ago
Ice Maker Not Working Properly (Refrigerator & Freezer Repair)
by cwvernon 18 years ago
