hi! i have a problem with my washer. it makes so much noise when spinning, i tried to open it and i found a leak behind on the bearing where the spinner is connected. is there a way to change the bearing or it has to be change the whole spinning assembly? what parts should i replace. the leak is on the bearing itself. thank you!
Most likely the rear bearing and the spinner support are gone bad. The rear bearing comes as a part of the rear outer tub. You have to replace the outer tub and the spinner assembly. This is a pretty big job. - The part number for the rear outer tub is AP3830512 - The part number for the spinner assembly is AP3830513 Gene.
