2 Pages<12
#11 Posted : Friday, August 6, 2010 6:48:22 PM(UTC)
How freely was the big pulley turning in both directions?
Robert11
#12 Posted : Friday, August 6, 2010 7:05:11 PM(UTC)
Robert11
If you hear the motor hum when you turn on to spin (but it doesn't spin), you may have a bad capacitor. Easy fix. Check capacitor to see if it's bad, if so, replace and wash away your troubles.:) :) :)
Jeneanne
#13 Posted : Saturday, August 7, 2010 12:53:17 PM(UTC)
Jeneanne
In response to Gene: The big pulley moves quite freely in both directions when move manually.
In response to Robert11: When testing the machine on spin cycle the last two days, the motor is no longer humming :( .
Jeneanne
slalomskie
#14 Posted : Sunday, August 15, 2010 7:37:51 PM(UTC)
slalomskie
Jeneanne
I am now having the same problem. It is not the wax motor issue as I have had this one before so I know what to look for. Lock light lit, pump draining water but when unit tries to spin the unit shuts down. I can hit the start button and the unit starts pumping water again then shuts down when trying to spin. Drum turns freely by hand.
Jeneanne
#15 Posted : Monday, August 16, 2010 6:25:59 AM(UTC)
Jeneanne
I thought it might be the motor so I tested it with an ohm meter and the motor is fine. I am now thinking it might be something in the switch or wash selection dial.
Jeneanne
Guest
#16 Posted : Sunday, September 25, 2022 5:52:05 PM(UTC)
Guest
Rank: Guest
United States
Mine is doing this. What was the fix?
Guest (6)
2 Pages<12
