brawer
#1 Posted : Monday, August 2, 2010 9:58:35 AM(UTC)
brawer
Hi, Most of the time the drain pump will not stop pumping. I found that if I lightly shake or bounce the machine the pump will stop and normal operation will continue. I do not know if it is the switch or float or??? Is there a repair manual that may walk me through the order of disassembly. Thanks
Gary
