opie
#1 Posted : Monday, September 10, 2007 4:10:07 PM(UTC)
opie
Terminal block got hot and melted have a green w/ yellow striped wire were does it connect is it the external ground it is soldered in with the white wire
#2 Posted : Tuesday, September 11, 2007 2:16:57 AM(UTC)
If you have a three prong outlet, that wire goes to the middle terminal on the terminal block
Stove wiring ? Terminal block (Oven Repair (including Ranges and Cooktops))
by jeffsdad 9/28/2017 8:59:21 AM(UTC)
Whirlpool Estates Dryer Relay Wiring ???? (Dryer Repair)
by Rachel_Ray 4/9/2011 9:19:42 AM(UTC)
