The Ed
#1 Posted : Thursday, July 29, 2010 6:12:07 PM(UTC)
The Ed
My Haier ESD310 dishwasher will not work. The door switch broke and the machine would not stop running. It would run full cycle then start over again. I shut off the breaker then replaced the switch. After replacing the switch and turning the power back on, the machine will not do anything. No lights and none of the buttons work. I have done some basic electrical testing. I have power to and through the switch, at the main board and at the control panel on the front. Does anyone know if there is a reset button or something similar on these machines???
