water despenser will not work in door already replace filter
Often the water line will freeze inside the door. To check this disconnect the water line at the bottom of the door, then try the dispenser with the line disconnected. If you get water at the line, then line if frozen inside the door. Take a look at this page GE Refrigerators Repair Guide
