The display on my Frigidaire range is dim. Is there a brightness adjustment on the Oven Control Unit? Do I have to replace the Oven Control Unit to fix this problem? Thanks for your help.
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Originally Posted by: rphilbeck55 The display on my Frigidaire range is dim. Is there a brightness adjustment on the Oven Control Unit? Do I have to replace the Oven Control Unit to fix this problem? Thanks for your help. I've seen a few of these do that. They just keep getting dimmer and dimmer. Probably a resister on the board dropping the voltage or maybe the display loosing its gas. Either way the only fix I know of is a new computer/clock Part number: AP2127094
Sorry its not better news.
Thanks for your quick reply on this.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a frigidaire control panel that is dim. The model number is FED367CESD. Can this be fixed?
