realtyc
#1 Posted : 15 years ago
realtyc
I had a problem with the water dispenser and ended up replacing both water valves. After the freezer valve constantly pumping water into the ice cube try I replaced the bad valve with a new one. Now I get no ice unless i pour water into the tray myself; any ideas ? Could I really need a third valve ?
#2 Posted : 15 years ago
Make sure the water feeding tube into the ice maker (#269 on the diagram) is not frozen up.
