jamesed
#1 Posted : Wednesday, August 13, 2008 10:54:48 AM(UTC)
jamesed
How do you get the ignitor shield off to change the ignitor?
It seems to be rivited on, but am not sure,do you have to take the entire assembly apart?
jamesed
#2 Posted : Friday, August 15, 2008 5:18:02 PM(UTC)
jamesed
Does anyone have any experience with this rotisserie,I wonder if I have to take the whole assembly apart
libertyappl
#3 Posted : Friday, August 15, 2008 6:21:24 PM(UTC)
libertyappl
Have you looked your model up under find parts on this website it has a complete break down of your rotisserie along with wire diagrams. Think of it as "some assembly required" in reverse :D
Nat
jamesed
#4 Posted : Saturday, August 16, 2008 8:29:32 AM(UTC)
jamesed
Yes but it doesn't show how the part is attached,this cover has the rather large ignitor under it,it looks as though it should pop off.After prying on it I finally used a small flashlight to look inside and it seems to be riveted.If so then the entire assembly need be removed and the rivets drilled out,just to change the ignitor?I was hoping that I am missing the obvious,anyone work on these?
