Can anyone help? :confused: I have a Sears Kenmore 80 Series Washer it will fill up but it will not agitate or spin. The washer is not making any kind of noise.
Do you have complete model#?
Originally Posted by: Debbyt  Can anyone help? :confused: I have a Sears Kenmore 80 Series Washer it will fill up but it will not agitate or spin. The washer is not making any kind of noise. Without a proper model number that's going to be a bit Difficult. It sounds like a top load washer? The easiest checks for you to make are: Raise the lid and check for a broken or missing lid switch plunger, you should hear a click when the lid is raised and lowered.(do this several times). No click indicates an inoperative switch,or damaged plunger assembly. With a proper model number , we can assist you more efficiently.
Originally Posted by: Debbyt  Can anyone help? :confused: I have a Sears Kenmore 80 Series Washer it will fill up but it will not agitate or spin. The washer is not making any kind of noise. The correct Model number is 110.25852400
Possible drive coupler.Part#285753A
