doug dreyer
#1 Posted : Tuesday, July 27, 2010 12:20:25 PM(UTC)
doug dreyer
I have a Neptune Gas dryer that shows 47 mins on the display...I can get it to reset....I can get it into "service mod" confirmed by the 'd' on display but I can't get it to display any error codes to determne what is wrong....any suggestions ? thx Doug
Joe / APP Team
#2 Posted : Tuesday, July 27, 2010 12:56:32 PM(UTC)
Joe / APP Team
Doug,
You mentioned you trird to run the diagnostic code test mode and could not.
Did you attempt to run any of the other tests, board out, key pad test etc?
I would believe, the most likely problem is a touch pad malfunction.
Do you have a multi meter, so you can circuit test each button on the key pad ?
I'm referring you to another sight:
http://servicematters.co...ibrary/docs/16023110.pdf
Page 9-12 thru 9-14 is the section that will refer to circuit test's and test modes for you control, key pads, and component run test's.
This would assist you better in diagnosing your problem.
I also attached the part number for your console touch pad assembly for your refernce should you need it.
Part number: AP4043121
