ofar
#1 Posted : Monday, July 26, 2010 2:13:36 PM(UTC)
ofar
The washer fills and stops at all different wash levels. However, when the water stops, the machine hums, and then trips the surge protector. There is the smell of something burning.
When the belt is removed the motor spins !!!!!!!!
ThatGuy
#2 Posted : Tuesday, July 27, 2010 6:13:45 AM(UTC)
ThatGuy
Groups: Expert
United States
Try turning the transmission pulley by hand. It sounds like your transmission is locked up.
ofar
#3 Posted : Tuesday, July 27, 2010 9:17:10 AM(UTC)
ofar
if that is the case, how do I fix that problem??????????
ThatGuy
#4 Posted : Tuesday, July 27, 2010 5:38:33 PM(UTC)
ThatGuy
Groups: Expert
United States
Well, if the transmission pulley is hard to turn or won't turn, then the transmission is probably shot. Its an expensive part and not easy to change. So it may be time for a new washer.
