Water is dripping from back of Housing Control in the fresh food compartment. Ice is also forming there as well as in the freezer compartment. From reviewing other post this points to a drain tube issue. If so, can someone tell me the steps to access and clear the drain tube? GE Model #GTS22JBPBRWW.
thanks all.
The drain hole is in the middle of the through drain (#622 on the diagram). You have to remove the rear panel in the freezer to access it. Use a hair dryer to defrost it and a hot water to make sure the drain is clean and open. A turkey baster can help. Make sure the other end of the drain hose (on the back of the refrigerator) is clean and open as well. Here are the breakdown diagrams and Replacement parts for General Electric GTS22JBPBRWW Refrigerator | AppliancePartsPros.comGene.
