It is trying to spin but is not draining so won't spin fast. What can I do?
Pete
Peter, Remove the front and rear access panels. Check if the drain pump is working when the control calls for drain/spin. Remove the drain hose (#41 on the diagram) and check for any foreign objects inside. - The drain pump Part number: AP4359940
Thank you very much. I will be working on it tomorrow. I didn't expect this much information and I sincerely appreciate it.
Pete
