The ice dispenser on my GE PSS26SGPSS dispenses water but will not dispense ice. When I try to dispense ice the freezer temporarily halts and the lights on the dispenser panel dim. I have replaced the front panel board on the door and that did not solve the problem. I removed the dispenser motor and tested it directly by plugging it in. The rotator turned without a problem. It is making ice but will not dispense it through the door. Could there be a problem with the ice maker itself or is there a possible issue with the main motherboard. I have also cleaned all the contacts at the bottom of the door.
The main board is most likely bad. What typically happens is when you try to use the dispenser the low voltage on the board drops out. Refrigerator repair guide
