accord
#1 Posted : Tuesday, August 12, 2008 8:13:56 AM(UTC)
accord
Some of the selections on the touchpad only work occasionally. Specifically the following items: Pre-heat, Keep Warm, and the following numbers 4,5 & 6. I can remove the touchpad panel and re-install it and sometimes it will work and other times it will not. If it does work, it may work for a day or it may work for a week or two. Is this an item that can be diagnosed and repaired or does it need to be replaced.
Frigidaire Model PLES389ECB - Part Nr. 318313825( I believe it was replaced with the identical part, but the new part number now is 318313830)
Thank You very much for your time and information.
Accord in Georgia
#2 Posted : Tuesday, August 12, 2008 4:40:19 PM(UTC)
Accord,
Most likely the problem is a bad control panel which has to be replaced.
The part# 318313830 is Appliance Parts Pros part number AP3951016
accord
#3 Posted : Tuesday, August 12, 2008 5:06:35 PM(UTC)
accord
Thank you for your help. Will order the new part. Other than cutting the power and swapping out all the connections are there any other precautions to consider?
Thank you again,
Accord
#4 Posted : Tuesday, August 12, 2008 5:42:04 PM(UTC)
Not much. Just do one connection at a time and label wires if needed.
GSS25XSRCSS Dispenser Touchpad Assembly (Refrigerator & Freezer Repair)
by asaha 1/3/2024 7:17:02 PM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Microwave touchpad (Microwave Repair)
by duguyisheng 7/6/2023 5:12:28 PM(UTC)
LG Touchpad Dishwasher Issue (Dishwasher Repair)
by m_roussakis 3/6/2023 4:07:58 AM(UTC)
Fridgidare FPBS2777RF6 Refridgerator Touchpad not working (Refrigerator & Freezer Repair)
by dbaker42 2/15/2019 6:36:30 AM(UTC)
Whirlpool Gold touchpad controls (Refrigerator & Freezer Repair)
by laga7788 1/8/2018 4:15:50 PM(UTC)
Whirlpool range touchpad won't display (Oven Repair (including Ranges and Cooktops))
by kleindon 10/6/2017 7:15:22 PM(UTC)
Touchpad repair? (Oven Repair (including Ranges and Cooktops))
by frEEk 1/30/2017 1:19:41 PM(UTC)
Dishwasher touchpad disintegration (Dishwasher Repair)
by griot 10/3/2015 3:31:00 AM(UTC)
WHIRLPOOL AccuBake 30" Slide-In Range Touchpad Issue (Oven Repair (including Ranges and Cooktops))
by mservice 2/7/2015 9:23:30 AM(UTC)
Erratic touchpad test results for failing Kenmore Elite Dryer (Dryer Repair)
by gmilo2 1/13/2014 5:49:01 PM(UTC)
Whirlpool double oven touchpad not working (Oven Repair (including Ranges and Cooktops))
by pszopiak 12/4/2013 4:12:51 PM(UTC)
How to Remove/Replace Touchpad (Dishwasher Repair)
by BaadDawg 12/2/2013 9:08:18 AM(UTC)
F1-8 Code, disconnected touchpad ribbon, then F1-7 error code (Oven Repair (including Ranges and Cooktops))
by sstark 10/1/2013 8:57:01 AM(UTC)
replace touchpad and control panel for ge spectra oven/range (Oven Repair (including Ranges and Cooktops))
by patcat2112 7/25/2013 4:00:38 PM(UTC)
