Larry1261953
#1 Posted : Tuesday, August 12, 2008 3:47:13 AM(UTC)
Larry1261953
I suspect someone bypassed the slide mechanism to save money. How is that possible? Dryer keeps running and won't shut off unless unplugged. It's a gas dryer and was set to a 30 minute cycle. The dryer is 6 month's old purchased new from AJ Madison out of NY.
ApplianceJunk
#2 Posted : Tuesday, August 12, 2008 9:55:13 AM(UTC)
ApplianceJunk
The wire to the timer motor may have been removed or you just have a bad timer.
Larry1261953
#3 Posted : Friday, August 15, 2008 12:44:47 PM(UTC)
Larry1261953
how could the wire to the timer be removed, it's under a security lock box I believe? Changed timer but same problem
