debbie558
#1 Posted : Monday, August 11, 2008 11:09:07 AM(UTC)
debbie558
F-6 on screen, loud humming, unresponsive. Had to unplug to turn off. After a few minutes I plugged it back in and got the same response. I have had this microwave for 7 years, it's in mint condition the only problems I have had are with the vent above the door constantly cracking and once the door itself cracked at the handel and hinge. What does F-6 mean? The manual says "call a technician". Can you be more specific as to what the problem is?
abadfish66
#2 Posted : Monday, August 11, 2008 11:36:37 AM(UTC)
abadfish66
F6 is going to be either the control board or keypad. Unplug the unit, open the door and slap the side of the microwave where the controls are, maybe this will get it to work while you decide if it's worth the money to fix it.
Whirlpool Gold Microwave vibrates while not in use (Microwave Repair)
by vonahnen 8/19/2013 1:14:25 PM(UTC)
Whirlpool Gold microwave is DEAD (Microwave Repair)
by j_hildebrand 11/30/2011 11:57:31 AM(UTC)
Whirlpool Gold Microwave/Oven Saga (Oven Repair (including Ranges and Cooktops))
by toc9231 7/26/2011 9:59:32 AM(UTC)
Changing Whirlpool Gold Microwave Oven (GMC305PDB1) Light Bulb (Microwave Repair)
by New2DIY 12/8/2010 2:00:10 PM(UTC)
Replacing A Whirlpool Gold Microwave Light Bulb (Oven Repair (including Ranges and Cooktops))
by ish2008 12/7/2010 4:32:07 AM(UTC)
Whirlpool gold microwave problem (Microwave Repair)
by pasricat 7/26/2010 8:49:52 AM(UTC)
Whirlpool Gold Microwave says "Door" when trying to use (Microwave Repair)
by dave3301 2/1/2010 2:42:32 PM(UTC)
Whirlpool Gold Microwave Broken Door Panel (Microwave Repair)
by bbrever 1/2/2008 3:54:36 PM(UTC)
