Well I seem to have a bad motor Old Part # 3395652 on my Kenmore Gas Dryer # 110.76722694 . . I am wondering if you have any suggestions on taking it off and exchanging it out, I have (So Far) taken it apart removing the front , drum, belt and pully to clean it, .But I have not removed the motor itself or messed with any other components. It looks like it is bolted with one bolt just under the motor and has one single connection for the power. Please advise how to remove (and if there are any secrets to a successful swap) . . Thanks again. .
PS My Model does not appear in my search for parts on this site is tere an alternate model I can order parts off of? :eek:
