danimaldds
#1 Posted : Sunday, August 10, 2008 5:53:27 PM(UTC)
danimaldds
Last time I used it the CL clean led was on and the water pump was still trying to pump out water. Tried to unplug and clear cycle, but when the power is on, it just pumps and nothing else. Now I obviously turned it off, and, cleaned the filters and screens and cleared the exhaust tube for the h2o. What could it be?? someone must know.. None of the controls work except on/off. It will show hr delay and cycle thru that, but it still only pumps out water , or no water since it's empty. It does pump out any added water..
#2 Posted : Monday, August 11, 2008 11:11:44 AM(UTC)
You can use the troubleshooting guide from one of our previous posts: http://forum.appliancepartspros...troubleshoot-manual.html
Here are the break down diagrams for the Bosch dishwasher Model SHU5315 UC/12 (FD 8003-)
carsonbaker
#3 Posted : Tuesday, August 12, 2008 8:10:22 AM(UTC)
carsonbaker
Thanks for your help hope i can get this fixed. I have a Bosch SHU5302UC/U06 dishwasher that stays in the drain cycle and will not clear. Any suggestions?
#4 Posted : Tuesday, August 12, 2008 2:22:05 PM(UTC)
carsonbaker,
You can use the recommendations from the above post.
Here are the break down diagrams for the Bosch dishwasher Model SHU5302 UC/06 (FD 7705-7912)
