We came home from vacation and the GE builtin open was beeping, error code displayed was F1. If I push clear it will stop for a few minutes then start again. Only if you run the oven will it not beep. The oven works fine.
I disconnected the ribbon cable and it beeps, error code f1 and the key pad doesn't work.
The model number is J TP 17 WOT1WW, can't find a model number with the O, not zero, in it. There is what looks like a part number on the part ERC-14800-RP/ 100-672-00, CN: 191D1066P001, can't find the part number either.
