lktnky
#1 Posted : Sunday, August 10, 2008 12:16:02 PM(UTC)
lktnky
We have an LG freezer-on-the-bottom, french-door refrigerator that is 13 months old. When I opened the doors this morning, both lights were out and I thought to just replace them, but thought it odd that both had burned out at the same time. When I opened it again in less than 5 minutes, the lights came on. This happened several times throughtout the day. DH pulled the bulbs & they're fine. Put them back in and now lights don't turn off when the door switches are depressed. Have taken the bulbs out so they don't heat up the inside.
Freezer is working fine (lights & cooling) and the upper refrigerator area seems to be cooling ok.
Can anyone help?:confused:
Thank heavens I found this forum!
ApplianceJunk
#2 Posted : Sunday, August 10, 2008 1:38:39 PM(UTC)
ApplianceJunk
Bad door switchs or relay on the control board.
lktnky
#3 Posted : Monday, August 11, 2008 5:54:22 AM(UTC)
lktnky
We've checked and the light switches do work. (When depressed w/doors open, fans kick in.)
Can anyone tell me where the control board is located?
Thanks again,
lktnky
