freezer nor fringe is cooling down. is not icing up so how do i test thermostate?
Do the compressor and fans inside the freezer and next to the compressor work?
Originally Posted by: Gene  Do the compressor and fans inside the freezer and next to the compressor work?
Gene. yes, the freezer fan and condenser fan are on. the overload sensor on the side of compressor snaps every few minutes and the compressor is pretty warm to the touch. the vaporizer in the freezer is not cooling down.
If the compressor overload clicks every few minutes, it has to be replaced. If you need the correct part number, post the serial number of the refrigerator.
Originally Posted by: Gene  If the compressor overload clicks every few minutes, it has to be replaced. If you need the correct part number, post the serial number of the refrigerator.
Gene. 19364341ar rev#19
The relay/overload assembly Part number: AP4009660
This part has been recently redesigned by the manufacturer and looks different. The installation instructions are included. Gene.
