Chris6767
#1 Posted : Friday, July 23, 2010 1:04:34 PM(UTC)
Chris6767
Dear Sir or Ma'am,
I have a Whirlpool Dishwasher; "Whirlpool Gold Quiet Partner III" GU2500XTPB3.
This is what the unit does.
1.) The Clean Light flashes 7 times then pauses and starts over.
2.) The rinse cycle comes on but no water enters the basin/tub.
That's it.
We have tried to reset the panel using this step; Pressed Heated Dry, Pressed Normal, Pressed Heated Dry and then Pressed Normal... (all within 5 seconds)... Result = all the panel lights came on but nothing more happened...
Before spending any more money was hoping to see if anyone might have a clue as to what i can look for myself... Had the panel replaced but that did not due it... seems to me its not getting any water?
Any ideas to help troubleshoot this would be greatly appreciated...
Thank you in advance for your help... i look forward to hearing from you.
#2 Posted : Friday, July 23, 2010 4:30:54 PM(UTC)
Does the dishwasher fills up with water at the beginning of the wash cycle? If it does, what is the water level?
