skimanforu
#1 Posted : 15 years ago
skimanforu
I have a LG washer and it quit working mid cycle. It will not power up at all. The control board smelled like it was burning and had smoke coming coming from one of the connectors. Did LG have problems with this? I assume the board is shot? Any help would be greatly appreciated.
skimanforu
#2 Posted : 15 years ago
skimanforu
I apologize - incorrect forum.
LG front load washer part id (Washer Repair)
by Cgreen0117 11 months ago
LG front load washer water leak (Washer Repair)
by Guest 3 years ago
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
LG Front Load Washer rotor only turns if given a push. (Washer Repair)
by Emailtim 5 years ago
LG Front Load Washer Barely Spins (Washer Repair)
by mckennwa 8 years ago
lg front load washer (Washer Repair)
by melindai 11 years ago
LG front load washer repair- special LG tool to remove the door front seal spring rin (Washer Repair)
by Paul Lukitsch 11 years ago
LG front load washer (Washer Repair)
by reichegw 12 years ago
LG front load washer no power (Washer Repair)
by waxmanak 12 years ago
Leaking LG front load washer (Washer Repair)
by klinkster 14 years ago
Lg Front Load Washer (Washer Repair)
by GIACOMO21 14 years ago
by Brandon1974 16 years ago
