deac4253shane
#1 Posted : Wednesday, July 21, 2010 11:05:10 PM(UTC)
deac4253shane
:confused: To my understanding when drying in the Air-Fluff Selection on the timer it is suppose to dry your clothes with no heat, just Air. After having my dryer worked on recently I have noticed that when drying in the Air-Fluff Mode it is drying our clothes with low heat through the whole cycle. Could the person who worked on it have gotten the wires switched on any of the thermostats to cause it to dry with heat in the Air-Fluff Mode? And, :confused: How can I check to see if they are switched? Such as, Looking at the thermostats Labels to where you can read the info example: the Red Wire H1, The Red/White Wire H3 on the lower thermostat closest to the heating element, how can you tell which wire goes on the thermostats Left or Right Terminal and so on with the other thermostats? The wiring Diagram is not very clear on that because if the thermostat is installed upside down you could be installing the wires on the wrong terminal. I did check the continuity of the thermostats & they did check ok. Can someone please asist me in my delima of why my dryer is drying with heat in the Air-Fluff Mode???????? Thanks!!! [EMAIL="deac4253shane@yahoo.com"]deac4253shane@yahoo.com[/EMAIL]
tmiller101
#2 Posted : Monday, August 27, 2012 4:02:13 PM(UTC)
tmiller101
Did you ever figure out what the problem was. Our dryer starter doing the same thing. Always has high heat in ever setting.
