mike.abel@charter.net
#1 Posted : 17 years ago
had a small fire in the microwave, nothing was damaged by heat, now the microwave does not power up, no display, completely dead. Looks like a small amount of black soot in the exhaust vent area. The only electrical part near there is a component called the "gas sensor". I have checked the fuse, it is good and verifiyed there is power to the unit. Could the gas sensor have been damaged by the small fire. If the Gas sensor was bad would it keep the unit from powering up at all?
abadfish66
#2 Posted : 17 years ago
abadfish66
Item# 1121 on the first diagram is your problem, not the gas sensor. This part is also known as a flame sensor and is designed to kill power when it detects over heating or a fire.
abadfish66
#3 Posted : 17 years ago
abadfish66
Here is the part you need
AP2023218
alexbest4u
#4 Posted : 15 years ago
alexbest4u
Same exact scenario, as described above (I had some flames that could potentially reach the gas sensor)
Please, help me select the right sensor in my case.
GE Spacemaker XL1800
Model # JVM1850BH06
Serial # HL900721B
