Sib
#1 Posted : 15 years ago
Sib
So I am a HVACR technition "commercial" I have never worked on a residential refer. Before I started tearing it apart I wanted to see if I can get some hints first.
The frig locks up . The compressor is not running. I cycle the power, via the plug. and it starts working it stays on untill it reaches set point, Everything freezes/cools down. Then the compressor turns off and will not come on again untill I cycle power again.
Any suggestions?
#2 Posted : 15 years ago
Your control module is bad AP3966011, nice thing about Frigidaire, all the control functions are in one, reasonably innexpensive, module.
