High I have a Kenmore Elite French Door with bottom freezer which is made by maytag/amana for sears, The fridge stopped working after the power went out, the freezer works fine, I do not hear the blower motor running, I was wondering how you replace the fan motor, from the back, any tips and possible other causes, I heard that there has been problems with fan motors going out on these units, I bought the Fridge in 1994 , any thoughts and comments would be appreciated, Also the compressor was replaced under warranty 2 years ago, so thats new, thank god
Repost with the correct model # in the box
Originally Posted by: richappy  Repost with the correct model # in the box The Model # is 596.75523400 its a Kemore Elite, french door Frig with bottom freezer, i think it is made by maytag/amana, thanks for quick response
Originally Posted by: richappy  Repost with the correct model # in the box This frig is not working, feeezer works, no fan blowing, the power went out for 10 hours , frig stopped working, but freezer works , thanks for helping, my question how do you take frig apart to get at evaporator fan and if you have any thoughts about what else could be wrong , thanks again
You will need your owners manual to trip the retaining tabs on the freezer door rails, then unscrew all the screws to remove the door. Then remove back freezer panel. Remove freezer fan and test.
