jaydfla
#1 Posted : Thursday, August 7, 2008 11:59:20 AM(UTC)
jaydfla
My washer started intermittently having problems going into the rinse cycle. I could force it into the rinse cycle by pulling the control knob in and out several times. I became less and less intermittent, so I ordered a timer from you and replaced same. It still has the problem. Apparently the timer wasn't the problem. Is there something that I missed?
fixme
#2 Posted : Friday, August 8, 2008 7:02:25 PM(UTC)
fixme
my washer (Kitchen Aid about 8-10 yrs) all of a sudden finish washing and I guess went into spin and broke the motor coupler. so it is not spinning, so then I took it apart and replace the coupler about $15 dollars. but get this it was hell cause I open the oil pan on the transmission and it spilled all over the washer so now Im stuck in a stump. dont know how to put or what kind of oil to use and where to put it in.
