Dryer gets hot enough to dry clothes BUT, timer runs fast so I have to reset the timer on the average of twice per load. Within the last year I have replaced the bearings and seals on this same dryer. (You guys helped me out on that one too)! Thanx for the excellent help PAA;)
Will it time out at "normal" speed on the timed cycle and not on the auto cycle.
Hello richappy What actually happens is the first time I sent the auto dry it runs very fast. I have to reset at full time and it runs and drys properly. Make sense ? Rockinga :confused: Originally Posted by: richappy  Will it time out at "normal" speed on the timed cycle and not on the auto cycle.
You either have a missing wire to the moisture sensor below the door in the front, or a bad pc board behind the control panel.
Please explain auto cycle vs. timed cycle :confused: Originally Posted by: richappy  Will it time out at "normal" speed on the timed cycle and not on the auto cycle.
Timed cycle runs the timer motor direct, auto cycle uses a sensor and a pc board to control timer motor.
