whburling
#1 Posted : Wednesday, August 6, 2008 7:44:54 PM(UTC)
whburling
igniters work at stove top. cleaned to ensure best spark possible. frequency ~ 5-8 hz
propane tank (40gn) newly filled. everything worked when I first hooked the just-filled tank up. just took off regulator to ensure there was gas in tank. plenty of gas came out of tank when I turned tank valve on. NOT sure if gas is coming out of regulator when hooked back up.
did have heavy rain storm today, but find it difficult to believe that rain would cause problem with regulator.
regulator is only about 1-2 years old.
there is no gas coming out of burners. bypassed ignition
system with matches but no gas to burn. no gas available for oven either so it seems as if the entire stove is not receiving gas or there is some sort of safety solenoid which shuts off gas for specific situations.
please help
Bil:)
whburling
#2 Posted : Thursday, August 7, 2008 7:05:48 AM(UTC)
whburling
my "no gas" problem was due to a failed regulator. Apparently the Precimex Mod 5001 fails in a shut off
mode OR something plugged up the small hole in the
tank/regulator connector.
replaced the regulator and everything worked.
GE Cooktop No Gas at Burners (Oven Repair (including Ranges and Cooktops))
by Perry401 3/13/2013 5:41:57 PM(UTC)
