fibreguy
#1 Posted : Tuesday, July 20, 2010 8:08:49 AM(UTC)
fibreguy
I'm posting this again. Just wondering if there anyone out there that maybe able to help me out?
My Kenmore dishwasher rinsing agent (Jet-Dry) compartment is always full and never seems to need refilling and the glasses always have spotty after each wash cycle?
Does anyone know why this is?
Read more: http://forum.appliancepartspros...asses.html#ixzz0uEtgi3AZ
http://forum.appliancepartspros.com
Joe / APP Team
#2 Posted : Tuesday, July 20, 2010 9:05:10 AM(UTC)
Joe / APP Team
First, Your rinse dispenser only releases a few drops of rinse agent (approximately 1/4 tsp)during a normal wash cycle. Depending on usage you may not see a major decline in the dispenser window.
On the other hand, you could have a defect in the dispenser switch and linkage, or the dispenser outlet could be clogged with old rinse agent and also will not dispense.
To access the rinse agent dispenser and components you will need to dismantle the inner door panel (plastic liner) from the outer door panel (metal panel)
If you do not feel comfortable dismantling the door you may want to contact a servicer to diagnose and repair your unit.
fibreguy
#3 Posted : Tuesday, July 20, 2010 9:24:24 AM(UTC)
fibreguy
Thanks for responding to my concern.
I haven't put any rinse agent in the dishwasher for about a year now and it's still looks full. Where is the rise agent released from so I can check if it maybe clogged? I've removed the inner panel already and the switch has two levers, one for the rise agent and the other is for the soap dispenser. How do I troubleshoot the switch to see if the rinse agent side of the switch is functioning properly?
Joe / APP Team
#4 Posted : Tuesday, July 20, 2010 2:01:17 PM(UTC)
Joe / APP Team
The opening for the rinse aid is under the fill cap. the small hole or slot just under the cap on the bottom side of the opening.
In most cases servicers would do a live 120 volt test at the switch to see if it worked and activated the dispenser and opened to release the rinse agent.
I would not reccomend you perform that test, you could hurt yourself.
If you do not find any debris or residue in the dispenser opening, I reccomend you have a servicer out to diagnose and repair your dispenser.
