mjbrown67
#1 Posted : Wednesday, August 6, 2008 11:11:01 AM(UTC)
mjbrown67
My Frigidaire Washer will quit while in use, seems that an overload switch opens. Have to wait 15 to 20 minutes and then it will restart. Not sure what may be causing this.
#2 Posted : Thursday, August 7, 2008 2:46:36 AM(UTC)
Does it quit while washing, or spinning?
mjbrown67
#3 Posted : Thursday, August 7, 2008 9:42:28 AM(UTC)
mjbrown67
While Spinning
#4 Posted : Friday, August 8, 2008 5:22:10 PM(UTC)
Pull the belt off the tranny and see if the tranny pully is hard to turn in the spin direction. If so, you should look for signs the tub bearings are going bad.
