Handychick
#1 Posted : Sunday, July 18, 2010 4:13:38 PM(UTC)
Handychick
Help, i'm not sure what my next step is. Everything in my fridge turns on, all fans, lights, compressor etc.. The coils have a nice even frost on them and when I turn the timer both of the defrost heaters turn on. I have a meter to check the continuity, however I am not sure how to do this on the thermo. The evaporator fan is turning fine, is it possible that the motor is bad and the fan still turns? Please help!
Handychick
#2 Posted : Monday, July 19, 2010 5:37:45 AM(UTC)
Handychick
Update: This morning I checked the freezer again and the heaters were on and working. I am assuming since they turned themselves on then it is not the timer, stat or heater. Please help I am stumped as to what to do next.
Handychick
#3 Posted : Tuesday, July 20, 2010 5:15:34 AM(UTC)
Handychick
Thanks in advance to any help. If you follow my posts you will see where I am at. I cannot figure this out, everything seems to be working as it should. This fridge is 15 years old and we just moved into this house and I can't afford to replace right now. Is it possible that I have such bad luck that after 15 years of running fine that the freon has started leaking?
