fegar
#1 Posted : Sunday, July 18, 2010 6:36:58 AM(UTC)
fegar
My fridge was not cooling but the freezer was working fine so I checked the evap coil and found it to be frozen over so I replaced the defrost heater, thermostat and timer (all purchased from here). Now the fridge is working but the freezer is frosting over really bad. I have checked the door seal and it appears to be fine. Any suggestions?
#2 Posted : Sunday, July 18, 2010 11:22:51 AM(UTC)
Go in the back and turn the defrost timer till the compressor stops, then pull the back freezer panel and check for defrost heater operation. If no-go,remove power and check your wiring connections. Heater and defrost thermostat must be in series. Would help if you had a meter. Rather rare new parts fail.
Freezer frosting over, fridge not cold (Refrigerator & Freezer Repair)
by spowel007 4/5/2014 2:20:16 PM(UTC)
Top of freezer frosting over (Refrigerator & Freezer Repair)
by fst-tlk 10/17/2011 12:22:30 PM(UTC)
frost free refrigerator/freezer frosting over on back wall or bottom freezer (Refrigerator & Freezer Repair)
by bwheeler 1/29/2009 2:57:04 PM(UTC)
