misterjim
#1 Posted : Tuesday, August 5, 2008 5:20:31 AM(UTC)
misterjim
when we close the refr. door the freezer door opens slightly. I have checked the seal with a dollar bill and it is tight all around. when you look at the front of the ref./ freezer the freezer door is lower at the top by about 1/4 of an inch. can this be adjusted? and is this the cause of the door opening?
#2 Posted : Tuesday, August 5, 2008 8:59:07 PM(UTC)
Check the washer on the freezer door bottom hinge (#29 on the break down diagram) and the bushing on the bottom of the freezer door (#22 on the break down diagram). Try to tilt the cabinet more toward the rear.
Here are the break down diagrams for the Frigidaire refrigerator Model FRS24WRCW1
