barkwaffle
#1 Posted : Monday, August 4, 2008 6:57:42 PM(UTC)
barkwaffle
Help! Whirlpool side-by-side fridge # ED5VHGXML two years old. Freezer too cold and icing up - fridge section too warm. Defroster problem? No air blowing through top left vent inside fridge section. Where do I start and what to check? Thanks! I see the sticky notes about common 3 items to check defroster and will check timer first. Anything specific I should know about the Whirlpool? And I'm not good with continuity tester - can someone walk me through exactly how to use it? (analog tester) Fridge is barely two years old. Thanks!
mahitas
#2 Posted : Thursday, March 12, 2015 11:36:13 PM(UTC)
mahitas
You might didn`t close the freezer door once. Need to defrost the air ways and check evap motor.
